Motherboard: Gigabyte 870A-UD3
Memory: F3-12800CL9D-4GBRL
CPU: Athlon II X4 635
I'm at a loss...
I just received and installed memory sticks from G.Skill. I go into the bios and change the timings to 9-9-9-24-2T and the CPU NB to +0.100V to get 1600Mhz. 30 minutes after boot and it BSODs. I test with Prime95 and it BSODs after 20-30 seconds. I then try the built-in memory diagnostics tool and the monitor turns black. Finally, I use memtest and get a stream of errors.
Bad motherboard? Bad CPU? The RAM is new, but all these errors...
I'm at a loss...
