Asrock M3A770DE <-> F3-10600CL7D-4GBPI
  • Asrock M3A770DE <-> F3-10600CL7D-4GBPI
    hello
    I got some problems with my combination. When I put all the 4GB (2x2) into my Board my PC gets Bluescreens and memory errors inside Windows. I cant find a working setting for that.
    When I Put 2GB into it...runs great without Bluescreen but i get the Amd driver is not responding error.
    Did you set timings to 7-7-7-24? Make sure memory settings are correct in BIOS.
      so i should have the config
      7-7-7-24
      Voltage on Auto
      and Frequenz on Auto !?
        Also check Command Rate is 2N, it often defaults to 1N
          got the 2 sticks working with 7-7-7-24 667Mhz
          but the amd driver issue is still there.
          Commandrate?..there is an Option where i can choose between 1T and 2T but no N?!
            2T - Intel use to use the T designation exclusively as AMD used the N, but now they seem to be interchangeable.
            Then if still getting the AMD driver error ensure you have the latest BIOS and drivers for the system
