register
Hi, I have Mother Xfx Nforce 790i Ultra , and buy DDR3-1600 Modell: F3-12800CL9D-4GBRL this model can be used on my motherboard? is compatible? Wonder why this model uses 1.5v , my motherboard is 1.8v default
Might want to check the range of voltage for your 790. When your mobo came out, FRAM generally ran at higher voltages prior to the release of the i7 CPUs. Since the i5s and i7s, voltages in DRAM have been dropping. If it supports the lower voltage, it should be fine, with these sticks you probably don't want to feed more than 1.6 to them.
