abcdefghij
Help with BSODs and reboots Sabertooth X58
Did you use the Marvel Driver from the ASUS website? Also keep in mind that SATA 6Gb is still new and needs to have time to work to the kinks, plus it?s not that much faster than SATA 3Gb at this time. One last thing if you were to revert back to your SATA 6Gb port, be sure to set up your boot drives accordingly, IDE or ACHI depending on your install.CPU I7-980X @ 3.81Ghz
MB ASUS P6X58D-E
GPU GTX480 @ 770Mhz
RAM 12Gb Patriot Viper Xtreme Division-2 DDR3 @ 1908Mhz
PSU Corsair AX 850W
SSD: Intel X25M 80Gb
HD 2x WD VelociRaptors 150Gb in Raid-0
Sager NP8662
CPU: Intel Q9100 @ 2.38 GHz
GPU: GTX 260M @ 612Mhz
RAM: G.Skill DDR3 1066Mhz 4Gb
SSD: Intel X25M 120Gb
