Dear G.Skill Support,
I have a serious question about setting up My Bios with G.SKILL NQ 12GB (6 x 2GB) Model F3-12800CL9T2-12GBNQ
My setup is:
Intel i7-980X 3.33Ghz (O.C. to 4Ghz)
Asus P6X58D-E Motherboard
G.SKILL NQ 12GB (6 x 2GB) DDR3 Ram
I made my system as much as possible stable with following BIOS settings but I still get some random freezing issues and first reason I find is because of Memory.
Temps Are completely fine (around 30-35C) (75-80C) on full Prime load) And I know people are fine with i980X O.C. to 4Ghz or 4.2Ghz easy
So,
My Current BIOS Settings:
Ai Overclock: Manual or X.M.P. - same thing.
CPU Ratio Setting: 20
Intel Speed Step: Disabled
BLCK Frequency: 200
PCIE Frequency: 100
DRAM Frequency: DDR4 - 1603Mhz
UCLK Frequency: Auto
QPI Timing Control: All on [Auto] or 9.9.9.24 on X.M.P. Automatic settings.
CPU Voltage Control: Manual
CPU PLL Voltage: Auto
QPI/DRAM Core Voltage: 1.40000
CPU Voltage: 1.35000
IOH Voltage: Auto
IOG PCIE Voltage: Auto
ICH PCIE Voltage: Auto
DRAM BUS Voltage 1.64
Could you please suggest me which settings I'd have to adjust to make my system more stable.
Another thing is about memory itself - do I have the right chips? Maybe I should have gotten something better? Performance-vise
I appreciate your GSkill time!!
My setup is:
So,
BLCK Frequency: 200
PCIE Frequency: 100
IOH Voltage: Auto
