Hi
I've looked through the forums and it doesn't appear that anyone has had this problem...
I've just RMAed some OCZ memory and replaced it with some g.skill. I inserted one stick (into slot 4) and the board started fine. I set the values in the bios and shut down.
I then put the other stick into slot 3 and now the PC won't start. The onboard diagnostics show the board is stuck at memory - "D1" is the reading. I have tried the memory in all four slots and the only ones that work are 2 & 4! The board assumed it had failed to due overclocking and has reduced its speed down to factory with jedec spec memory timings. The slots 1 & 3 still fail at this reduced speed. The OCZ memory did not fail in slots 1 and 3 (just wasn't reliable at rated speed).
Neither of the G.skill sticks appear to work in either slot 1 or slot 3, so I am unable to use dual channel mode.
I have tried raising the northbridge voltage by 0.1v but that didn't help either!
Anyone know what might be going on?
Dan
Dan
