F3-10666CL9D-8GBRL question
  • F3-10666CL9D-8GBRL question
    Hello
    I'm going to buy a new computer, but I have a question about G.SKILL Ripjaws 8GB DDR3 kit (2x4GB) PC310666 1333MHz 9-9-9-24 CL9 (F3-10666CL9D-8GBRL)
    The parts are:
    ASUS Crosshair Formula IV Motherboard
    AMD Phenom II X6 1055T CPU
    My question is: Will the memory that I listed above fit and work on that motherboard?
    Thanks for all answer
    Nesumar from Norway.
    Will there be any answer to this question? Cause I'm planning to buy same mobo and ram combo with Phenom II 1090t processor
      Should be fine with the RipJaws
        Yes, "should be" and "are" are two totally different things. I got this memory kit with an Asus motherboard that "should be" fine with it, but it isn't. Look on the list of certified memory for your motherboard, that's the best way to know if it will work.
          It'll definitely work. Plug and play.
