Hi GSkill,
I've been having many stability problems when running a certain game, an MMO that kept crashing madly (you can guess which). Contacting the MMO company, and following endless tech-support email ping-pong, I was told that to receive support I need to reach a 1:1 FSB : DRAM Freq ratio, for stability sake.
Being an overclocking newb (not n00b) that I am, I set about a small research into what I should do. I've gotten the latest BIOS + drivers to everything to begin with, and I am interested in getting to the golden 1:1 without any special OC (my rig is powerful enough as it is for now).
Starting with a ratio of 1:5 (FSB 133Mhz, DRAM at 666Mhz), and wanting the CPU (stocked at 2.66Ghz) to run at 2.8Ghz, I tried the following settings:
Ai Overclocking Tuner: X. M. P. (as per your recommendation I've read)
FSB: 200Mhz
CPU multiplier: 14 (= CPU @ nice solid 2.8Ghz)
With this I've gotten to a ratio of 2:8 (why isn't it 1:4 by the way? ...)
I have several questions:
1. Cpu-Z states that the X.M.P. profile of the memory should be: 7.0-7-7-24-34-2T
But my board will only set it to 7.0-7-7-24-89-2T (tRFC = 89 here)
Value tRFC 79 being the lowest stable, and nothing close to Cpu-Z's 34
Is this anything to worry about? how does this affect the memory frequency?
2. On the Memory tab, field Channels # shows "Dual" which is good, but field DC Mode is empty instead of showing "Symmetrical".
Is this a problem?
3. I can't, for the life of me, get the ratio to anything closer to 1:1. 2:8 currently is the best I can.
- Is there anything I can do without completely crippling my system?
- If this isn't possible to reach, can you please write it so I may show the game company?
- How do I change the DRAM frequency, or is it only a result of some calculation with the many timing values and cannot be changed directly?
Thank you very much in advance,
Awaiting reply,
Spade_of_Blue
============ Cpu-Z Data for Reference (edited for length) ============
CPU-Z version 1.55
Processors
Number of processors 1
Number of threads 4
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Core 1
-- Thread 0 2
-- Core 2
-- Thread 0 4
-- Core 3
-- Thread 0 6
Processors Information
Processor 1 ID = 0
Number of cores 4 (max 8)
Number of threads 4 (max 16)
Name Intel Core i5 750
Codename Lynnfield
Specification Intel(R) Core(TM) i5 CPU 750 @ 2.67GHz
Package (platform ID) Socket 1156 LGA (0x1)
CPUID 6.E.5
Extended CPUID 6.1E
Core Stepping B1
Technology 45 nm
Core Speed 2809.1 MHz
Multiplier x FSB 14.0 x 200.7 MHz
Rated Bus speed 3611.7 MHz
Stock frequency 2666 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x
L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 4 x 32 KBytes, 4-way set associative, 64-byte line size
L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size
L3 cache 8 MBytes, 16-way set associative, 64-byte line size
FID/VID Control yes
Turbo Mode supported, disabled
Max turbo frequency 3200 MHz
Max non-turbo ratio 20x
Max turbo ratio 24x
Max efficiency ratio 9x
TDP Limit 95 Watts
TDC Limit 89 Amps
Core TDP 89 Watts
Uncore TDP 6 Watts
Power @ 9x 14 Watts
Power @ 10x 17 Watts
Power @ 11x 20 Watts
Power @ 12x 25 Watts
Power @ 13x 30 Watts
Power @ 14x 36 Watts
Power @ 15x 43 Watts
Power @ 16x 51 Watts
Power @ 17x 60 Watts
Power @ 18x 70 Watts
Power @ 19x 82 Watts
Power @ 20x 95 Watts
Max bus number 63
Attached device PCI device at bus 63, device 2, function 1
Attached device PCI device at bus 63, device 3, function 4
Chipset
Northbridge Intel DMI Host Bridge rev. 11
Southbridge Intel P55 rev. 05
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR3
Memory Size 4096 MBytes
Channels Dual
Memory Frequency 802.6 MHz (2:8)
CAS# latency (CL) 7.0
RAS# to CAS# delay (tRCD) 7
RAS# Precharge (tRP) 7
Cycle Time (tRAS) 24
Row Refresh Cycle Time (tRFC) 89
Command Rate (CR) 2T
Uncore Frequency 3210.4 MHz
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR3
Module format UDIMM
Manufacturer (ID) G.Skill (7F7F7F7FCD000000)
Size 2048 MBytes
Max bandwidth PC3-10700 (667 MHz)
Part number F3-12800CL7-2GBRH
Number of banks 8
Nominal Voltage 1.50 Volts
EPP no
XMP yes
XMP revision 1.1
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 5.0-5-5-14-19 @ 380 MHz
JEDEC #2 6.0-6-6-17-23 @ 457 MHz
JEDEC #3 7.0-7-7-20-27 @ 533 MHz
JEDEC #4 8.0-8-8-22-30 @ 609 MHz
JEDEC #5 9.0-9-9-25-34 @ 685 MHz
JEDEC #6 10.0-10-10-28-38 @ 761 MHz
XMP profile XMP-1600
Specification PC3-12800
Voltage level 1.600 Volts
Min Cycle time 1.250 ns (800 MHz)
Min tRP 8.75 ns
Min tRCD 8.75 ns
Min tWR 12.50 ns
Min tRAS 30.00 ns
Min tRC 42.50 ns
Min tRFC 110.00 ns
Min tRTP 7.50 ns
Min tRRD 7.50 ns
Command Rate 2T
XMP timings table CL-tRCD-tRP-tRAS-tRC-CR @ frequency (voltage)
XMP #1 7.0-7-7-24-34-2T @ 800 MHz (1.600 Volts)
DIMM # 2
SMBus address 0x52
Memory type DDR3
Module format UDIMM
Size 2048 MBytes
Number of banks 8
EPP no
XMP yes
XMP revision 1.1
Min tRP 8.75 ns
Min tRCD 8.75 ns
Min tWR 12.50 ns
Min tRAS 30.00 ns
Min tRC 42.50 ns
Min tRFC 110.00 ns
Min tRTP 7.50 ns
Min tRRD 7.50 ns
Command Rate 2T
Monitoring
Mainboard Model P7P55D EVO (0x0000028F - 0x16D0C678)
LPCIO
LPCIO Vendor Winbond
LPCIO Model W83667HG-A
LPCIO Vendor ID 0x5CA3
LPCIO Chip ID 0xB3
LPCIO Revision ID 0x53
Config Mode I/O address 0x2E
Config Mode LDN 0xB
Register space LPC, base address = 0x0290
Hardware Monitors
Hardware monitor Winbond W83627DHG
Voltage 0 1.22 Volts [0x99] (CPU VCORE)
Voltage 1 1.74 Volts [0xDA] (VIN1)
Voltage 2 3.41 Volts [0xD5] (+3.3V)
Voltage 3 5.11 Volts [0xD5] (+5V)
Voltage 4 11.77 Volts [0xD3] (+12V)
Voltage 6 0.61 Volts [0x4C] (VIN6)
Temperature 0 51?C (123?F) [0x33] (SYSTIN)
Temperature 1 51?C (123?F) [0x66] (CPUTIN)
Temperature 2 49?C (120?F) [0x62] (AUXTIN)
Fan 0 848 RPM [0xC7] (SYSFANIN)
Fan 1 1068 RPM [0x4F] (CPUFANIN0)
Fan 3 884 RPM [0xBF] (CPUFANIN1)
Hardware monitor Intel Core i5 750
Power 0 36.53 W (Processor)
Temperature 0 52?C (125?F) [0x2F] (Core #0)
Temperature 1 48?C (118?F) [0x33] (Core #1)
Temperature 2 53?C (127?F) [0x2E] (Core #2)
Temperature 3 46?C (114?F) [0x35] (Core #3)
Hardware monitor Radeon HD 5870
Temperature 0 41?C (104?F) (GPU Core)
FSB: 200Mhz
Is this a problem?
Awaiting reply,
Spade_of_Blue
CPU-Z version 1.55
Processors
Number of threads 4
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Core 1
-- Thread 0 2
-- Core 2
-- Thread 0 4
-- Core 3
-- Thread 0 6
Processor 1 ID = 0
Codename Lynnfield
CPUID 6.E.5
Extended CPUID 6.1E
Core Stepping B1
Technology 45 nm
FID/VID Control yes
Max turbo ratio 24x
TDP Limit 95 Watts
TDC Limit 89 Amps
Core TDP 89 Watts
Uncore TDP 6 Watts
Power @ 9x 14 Watts
Max bus number 63
Chipset
Memory Type DDR3
Channels Dual
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR3
Module format UDIMM
Size 2048 MBytes
Number of banks 8
EPP no
XMP yes
XMP revision 1.1
Min tRP 8.75 ns
Min tRCD 8.75 ns
Min tWR 12.50 ns
Min tRAS 30.00 ns
Min tRC 42.50 ns
Min tRFC 110.00 ns
Min tRTP 7.50 ns
Min tRRD 7.50 ns
Command Rate 2T
DIMM # 2
SMBus address 0x52
Memory type DDR3
Module format UDIMM
Size 2048 MBytes
Number of banks 8
EPP no
XMP yes
XMP revision 1.1
Min tRP 8.75 ns
Min tRCD 8.75 ns
Min tWR 12.50 ns
Min tRAS 30.00 ns
Min tRC 42.50 ns
Min tRFC 110.00 ns
Min tRTP 7.50 ns
Min tRRD 7.50 ns
Command Rate 2T
Monitoring
LPCIO
LPCIO Chip ID 0xB3
Config Mode LDN 0xB
Hardware Monitors
RAM Ratio.. that's the first time I've heard that from a game company.. haha
Is it still common to have such a value when installed all 4 slots?
