Thanks a lot for your hospitality !
I read the forum for a few hours and I'm impressed by the technical answers i found here.
Sorry in advance for the quality of my English, I am a French frog ^^
So i'm here because i want to refresh my config with a new motherboard (x48) and a new ram (8 go 1600 mhz) and i need to know which module i have to choose among them:
F3-12800CL8D-4GBTD 2 x 2 Go PC12800 Trident Series x2
8-8-8-24
1,65 V
(seems to have been designed for the x48 chipset)
F3-12800CL7D-4GBRM 2 x 2 Go PC12800 Ripjaws CAS 7 x2
7-8-7-24
1,60 V
(seems to have been designed for the P55 chipset)
F3-12800CL7D-4GBECO 2 x 2 Go PC12800 CAS7 ECO x2
7-8-7-24
1,35 V
F3-12800CL7Q-8GBRM 4 x 2 Go PC12800 Ripjaws CAS 7
7-8-7-24
1,60 V
F3-12800CL7Q-8GBECO 4 x 2 Go PC12800 CAS7 ECO
7-8-7-24
1,35 V
The motherboard I will buy is a ASUS P5E3 Pro
Chipset: X48 Intel? X48 / ICH9R (Intel? Extreme Memory Profiles)
Front Side Bus: 1600/1333/1066/800 MHz
Memory: 4 x DIMM, 8 Go
DDR3 1600/1333/1066/800 Non-ECC,Un-buffered Dual Channel memory architecture
Here is the rest of my config:
CPU: Q9550 2.86Ghz
HDD: Raid 0 2x 160 Go 8mo 7200 tr/min.
GPU: Crossfire HD4850 Gainward Golden Sample.
PSU: Seasonic 600W Modulaire
Case: Corsair 800D
OS: Seven x64
Which one would be the more safety for a 8 GB system ?
which kit would be as close as possible to 1600 Mhz with 8 GB ?
ECO ? Ripjaws ? Tridents ?
I guess my CPU can go to 1600 mhz FSB easily.
Thank you for the help
8-8-8-24
1,65 V
7-8-7-24
1,60 V
7-8-7-24
1,35 V
7-8-7-24
1,60 V
7-8-7-24
1,35 V
CPU: Q9550 2.86Ghz
Case: Corsair 800D
OS: Seven x64
