Giagabyte X58A-UD5 & 1600 - 6Gig
  • Giagabyte X58A-UD5 & 1600 - 6Gig
    Hi
    I am going to buy one of these triple channel 6 Gig packs
    1- F3-12800CL7T-6GBRH
    2- F3-12800CL7T-6GBPI
    3- F3-12800CL8T-6GBRM
    4- F3-12800CL6T-6GBTD
    My main board is GigaByte X58A-UD5 and CPU is Intel Core i 7 - 930 that its default freq for ram is 1066 and 800.
    I am not familiar with over clocking at all. what should I do after installing ram modules in BIOS ??? is there sth like xmp profile for 1600 or i need to adjust its parameters manually ?
    if its not automatic can u tell me the parameters for it ?
    You can simpy set Extreme Memory Profile to "Profile 1" and that will configure the memory for you. Let us know if you encounter problems.
      Thanks for your quick reply , there is another question :
      1- After selecting xmp profile in BIOS and make system to use 1600 freq does this raise the cpu temp ? how much ? Is there any need to use some cooling facilities rather than cpu stock one's?
      2- I have seen some issues about not detecting the whole ram capacity in BIOS and Windows,( 6G --> 4G ), and the sticky thread solution in the forum solve it by manually setting parameters,its against simply selecting xmp profile in BIOS,whats the matter? If i misunderstood please let me know
      Thanks a lot
        1. DDR3-1600 should be fine. Only DDR3-2000+, you will need to use other than stock CPU cooling.
        2. There are many reasons for missing capacity. Read the sticky for more information.
