Hi - I was wondering if i were to purchase the Pi series memory, would i be able to use an after market CPU Air cooler and utilize all 6 memory slots, due to the size of memory heat sinks.
If yes does any one have a recommendation or a model number of the product that was able to fit? The board that i will be using it with is: ASUS P6X58D-E. Would like to overclock a 930 to 4Ghz.
Thank you!
Thank you!
