Trident F3-16000CL9T 12gbt + asus rampage3 + i7 980x
  • Trident F3-16000CL9T 12gbt + asus rampage3 + i7 980x
    Today i've bought the g.skill trident DDR3-2000 PC3-16000CL9T 12go 2x(2048mo x 3), and i'll like to have some help to set it with my motherboard asus rampage3 extreme and my cpu i7 980x. I got the latest bios, the 602. Thx
    Try these settings:
    AI overclock - manual
    OC from CPU level up - auto
    OC from Memory level up - DDR3-2000
    CPU Ratio setting - 21
    CPU Turbo Power Limit - disable
    CPU configuration
    CPU Ratio Setting - 21
    C1E Support - disable
    Hardware prefetcher - enable
    Adjacent Cache line prefetcher - enable
    Intel Virtualization tech - disabled
    CPU TM Function - disable
    Execute Disabled bit - disabled
    Intel HT Technology - disable
    Active Processor Cores - all
    A20M - disabled
    Intel C-STATE tech - disabled
    BCLK frequency - 167
    PCIE frequency - 100
    DRAM frequency - 2000 MHz
    UCLK frequency - 4000 MHz
    QPI frequency - auto
    Dram Timing Control
    DRAM CAS# Latency - 9
    DRAM RAS# to CAS# Delay - 9
    DRAM RAS# PRE Time - 9
    DRAM RAS# ACT Time - 24
    DRAM Timing Mode - 2N
    All others can be on AUTO
    CPU voltage - 1.32V
    QPI-DRAM voltage - 1.60V
    DRAM Bus voltage 1.60V
      Well, i've tried your setting but it doesn't work. When i've restarted, i had the message " overclocking failed" , i've disable your setting and i reloaded the default setting. If you have another solution ...thx. Maybe can i use Ai overclock = XMP ? i dunno. Actually all is in "auto" and the memory is at 1333mhz.
        You can use XMP, but you will still need to adjust QPI/DRAM Voltage. You need to find the precise voltage for this value. Start from DDR3-1600 then work up to DDR3-2000, that will give you a better idea of what voltage is needed.
          I've retryed your setting in your first post and now i've the led cpu "red" on my motherboard. I hope that my cpu isn't dead :/ My computer doesn't boot and i have a black screen....I'm using an other computer actually to talk there. I'm very very sad about it. Do you have some sugestions ?
            I've tryed all, clear cmos, reset ....but the led cpu is always in red, and the computer doesn't boot :/ always a black screen....
              Did you pull the battery? With power off from power supply, remove battery, reinstall, then power back on PSU and try again.
                yep, i've removed the battery and reinstall it, but always the same problem...
                  Remove the CPU, reinstall it, and see if problem persists.
                    i'm with a watercooling. Tomorrow i'll go to the shop who has installed it for the diagnostic... thx anyway
                      Finally, the shop could repair my computer, but don't use the setting in the first post if you don't want to crash your bios and your cpu. If you use it, after you'll need to make a hot flash to rebuild your bios, if your motherboard and your cpu aren't destroyed. :/ Very dangerous setting for your computer there.
                        it's not a dangerous clocking / setting at all, it's quite mild for the Rampage III Extreme seeing as it's capable of memory clocks of upto 2200...
                        the main issue here is probably the fact that according to ASUS's memory list for the board, it does not support 12gb of this memory (6 sticks). it will only support 3 sticks of this specific memory, 6 probably makes the qpi highly unstable.
                          Do like you want, i know that when i've tested this setting, after, i had to make an hot flash to use my computer.
                            This is why we don't suggest overclocking to those that do not understand how to. You should stick to DDR3-1333 if you do not want to risk your hardware, or take it to an overclocker. NOT a "professional" technician, most don't have a clue either.
