Hello everyone.
Model of the motherboard:GA-MA790GPT-UD3H
Model of the memory:Model F3-12800CL9D-4GBNQ
Model of the CPU:AMD:PII 955 be c2
Bought these components about three month ago. Put everything together and started running at 1600 Mhz, 9-9-9-24 2T
Computer was never totally stable. Strange thing was 3D application always worked fine, Computer locked up during browsing using flash etc. Usually after<24 hour uptime.
Ran a memory test and showed no errors, ever.
Started running at 1333Mhz,9-9-9-24 1T and computer runs problem free.
I would like to run at 1600 Mhz again. I tried to increase mem voltage to 1.65V, that didn't help.
What do you guys suggest I do different?
If I am stuck at 1333Mhz, you think I can use faster timings?
Thanks for your help.
Learux
Learux
