Did you set the ALL the timings to auto when in docp 9 10 9 24 2t the timings should auto ajust 9 9 9 24 1t
Crosshair IV AMD 1090t GSKill Trident 4GB (2x2GB) ~ overclocking ram above 1600mhz
A bit of a late reply but I Just Recently updated my bios so I thought I would give overclocking this ram another try:
I got the ram up to 1846 mhz (7-8-7-24-1T) (from 1600mhz) and it is stable (ran prime95 for 9+ hours)
230fsb
x17 multiplier
cpu 1.4v
I have ran into another snag though,
My CPU and northbridge temps seem very high:
CPU Idles at around 46 C and northbridge idles at around 56 C
At full load my cpu temp reaches 73 C and northbridge reaches 70 C
Even at stock speeds temps were very similar
My case has pretty bad air flow (So does my bedroom)
Do you think these temps could be preventing me from overclocking the northbridge successfully to get the ram up to 2000mhz
Thanks again for any help
