I ordered this ram G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Dual Channel Kit Desktop Memory Model F3-12800CL9D-4GBNQ Because I had a bad stick.I waited 2 weeks for the replacement.I set the timings on the ram,but there are alot more settings after the 9-9-9-24.. in the bios for my board.I set multiplier so it reads 1600MHz,but just ended putting it back to default.I'm not sure if I have it set correct.Plus the fact I dont even think I have the correct ram that I purchased.Its one thing to get bad ram,but now this..........
SiSoftware Sandra information- It says my ram is F3-12800CL9D-2GBNQ 2GB Dimm DDR3 PC3-12800UDDR31600 (9-9-9-25 4-34-10-5)
cpuz information- It says F3-12800CL9D-2GBNQ Module size 2048 MB PC310700(667MHz)
The sticker on the box i purchased, and the ram sticker reads F3-12800CL9D-4GBNQ DDR3-1600 PC3-1800 2x2048 CL9-9-9-24 1.5V
I don't understand this at all.First I get bad ram,now it seems they sent cheaper ram with the right sticker.
Any help is greatly appreciated.I just want to play games.Definitely not these type of games
Specs...
Antec 900
AMD Phenom II X4 955 Black Edition Deneb 3.2GHz Socket AM3 125W Quad-Core Processor Model HDZ955FBGMBOX - Retail
GIGABYTE GA-MA790GPT-UD3H AM3 AMD 790GX HDMI ATX AMD Motherboard - Retail
COOLER MASTER Hyper 212 Plus Intel Core i5 & Intel Core i7 compatible RR-B10-212P-G1 120mm
CORSAIR CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 .
EVGA 01G-P3-1158-TR GeForce GTS 250 1GB 256-bit DDR3 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card - Retail
AMD Gift - Call of Duty Modern Warfare 2 Coupon - Retail
LITE-ON 24X DVD Writer Black SATA Model iHAS424-98 LightScribe Support - Retail
Rosewill RC-401-EX 10/ 100/ 1000Mbps PCI-Express Gigabit Low Profile Network Card - Retail
(2) Western Digital Caviar Black WD7501AALS 750GB 7200 RPM SATA 3.0Gb/s 3.5" Hard Drive -Bare Drive
(1) Western Digital Caviar Blue 320GB 7200 RPM SATA 3.0Gb/s 3.5" Hard Drive
G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Dual Channel Kit Desktop Memory Model F3-12800CL9D-4GBNQ - Retail
Specs...
Antec 900
