- Corsair TX 850W
- Gigabyte 790xta-ud4 1.0 (bios f3c)
- F3-12800CL7D-4GBECO
- AMD Phenom II x4 965 BE 3.4Ghz
- Raid 0 WD 250GB RE3
- WD 1TB
- XFX HD5870
Strange Cold Boot/Start problem.
If my pc stay off for some hours, when i turn it on, it post...but after 1-2 second after the "windows bootmanager" the pc freeze with the hdd led light on.
I have to press reset (ctrl+alt+del not working) to reboot.
i have to do this operation 2 or 3 times. Sometime the pc run the boot process till windows login screen, then it freeze! Sometime the pc run and i can do the login.. but after some second on the desktop it crashes! More the pc is hot more long it resist
Always, after max 4 reboot, the pc do the post, boot and windows start without any problem.
Then i can run everything (Burn in test, memory test, etc) i have no issue till next "cold boot".
If i do the shutdown, and reboot without a long pause (like the night) the pc reboot with no problem.
I have this "freeze" problem only i turn on the pc after the night or some hours. It is like a "diesel" engine: i must wait the pc is "hot" the it run without problem.
I have do another test: after a cold boot i have pressed F12 to select the HDD to do the boot.
Then i have take a coffee, and after 10 minutes a have selected my boot hdd: so the system warm up in the pause... and then it do the boot without any freeze!
This problem is very annoiyng!!!! Because after numerous reboot, then the pc i ROCK SOLID and i can play o working endless!
My PSU is new, i have controlled voltages and they are perfect, cpu run fine (otherwise my cpu would not have passed stress testing), memtest with one memory module, or two, run without errors (when the system is warmupped sorry for my poor english).
Only thing i have to test is a memtest after a cold boot. If i find errors in this situation (memtest on cold boot)... can be a problem of the ram or of the MB? Thanks!
(sorry sorry sorry for my poor english!)
