F3-12800CL9D-4GBNQ 1600 Problem solved
  • F3-12800CL9D-4GBNQ 1600 Problem solved
    Hello all,
    i just got random Blue Screens freezes on Windows 7 64bit when using the default Timings 9-9-9-24 2T 1,5Volt.
    Mainboard Asus M4A79XTD EVO
    CPU Phenom X4 965 Black Edition C3 Stepping.
    8GB Memory (2 x 4GB Kits)
    The System is now running stable with Memeory using clocks as followed:
    7-8-8-19 1T 1067Mhz
    8-8-8-22 or 24 1T 1333Mhz
    When switching back to 1600 Mhz i still got Bluescreens.
    So it seems to be that the CPU is causing Problems when using more then 1333Mhz @ Memory Modules.
    Hope this will Hep out other Members to solve there Problems.
    If anyone using 1333Mhz it will be nice when you should Post your Timings so i can test out the best Performance.
    Greetings Markus
    Thanks for the info
      I'm surprised you're having issues with the C3 965 @ 1600. Which BIOS are you running on the EVO?
        The latest Bios 0901 and no Chance to get the System stable @ 1600Mhz i tried it over weeks
        Now the System runs stable and im glad that i have not to reinstall Windows again because the system crahes so many times (the most times after Cold Start) ............... thats crazy.
        Greetings Markus
          Hopefully you can see that Images ...........
          [IMG][/IMG]
          [IMG][/IMG]
          Greetings Markus
            Well, I'm very sorry you have issues but you have opened my eyes a little. I'm rethinking the EVO now...
              If someone got any Idea how i should get the System stable @ 1600 without Coldboot issue, System Crahses, Bluescreens ....... plz let me know and i will give it a new try.
              Greetings Markus
                Please send the memory in for new replacements if you are having cold boot problems.
                  OK thats a good Idea but im from Germany so wich Adress i may use? and do you need a copy of the billing ?
                  I never send anything before to Repacement
                  Greetings Markus
                    You do not need a copy of billing. Simply visit our website for complete RMA procedures:
                    http://www.gskill.com/rma.php
                      Ah thx found it.......... but what does
                      Original Invoice Number:
                      and
                      Original Invoice Date:
                      mean im a bit confused that ?
                      Markus
                      ok finsihed i think the Invoice Number is the billing number from the (reseller) alternate
                      thx for your patient
