problem with p7p55 lx
  • problem with p7p55 lx
    hello !
    im french sorry for my bad english
    i have g-skill trident F3-16000CL9D-4GBTD
    motherboard asus p7p55 lx
    i have the latest bios ( BIOS 0714 )
    when i on the pc im getting just one beep sound comming from the ram
    everything are find i can play games but the problem is i cant extract big rar files
    everytime the files are corrupt so i used memtest and im getting error every second
    so i tried both ram separately and both works find im getting no error from memtest
    the problem is both ram together doesn t works find
    so i want to know if the problem are because maybe the ram are not compatible with asus p7p55 lx
    or maybe the bios setting are wrong
    please help me
    best regards
    First might check and make sure Command Rate is at 2t or 2N, also check tRFC, will want about 68, make sure your base timings, speed and DRAM Voltage are input manually, don't rely on AUTO settings. If this doesn't work, can you post your BIOS settings
      hello !
      thanks for reply
      here is my bios on default setting
      please help me to set the bios
      INTEL CORE I5 750
      Cooler Master Hyper 212 Plus
      ASUS P7P55 LX
      G-SKILL TRIDENT F3-16000CL9D-4GBTD
        hello sory for the size here it is
          Simply enable the XMP Profile under "Ai Overlock Tuner" and everything should run just fine.
