I have two memory modules in my computer. They are supposed to be the same, though I see different numbers in the timing tables.
Here is DIMM1:
And DIMM3:
I thought the timing table was just data stored in a bit of ROM, and would be the same for each module in a pair.
My computer works, though there are some odd things. The OC Genie, for example, underclocks my cpu significantly when it is enabled.
Here is DIMM1:
And DIMM3:
