Here are my specs (stable)...
CPU: Phenom II x3 720 @ 3.5 Ghz
RAM: G.skill Ripjaws 4gb @ 1333
MB: MSI N980-G65
PSU: Antec 1000w
CPU-NB @ 2600
HT link @ 2000
In the bios i change the memory divider to 1/4 for 1600 and i set the timings manually to 9-9-9-24 2T at auto(1.5v). I cant pass IBT(Intel Burn Test) at these voltages and in memtest i get errors on the first pass on test #8. Now in order for me to pass IBT i had bump the voltage to 1.6v, also by doing this in memtest i can complete two full passes but on the 3rd or 4th time around i get errors again ONLY on test #8. So either i have to bump the voltage higher than 1.6 or it could be my processor cause its a C2 and not a C3. If its my processor im trying to rule the ram out. Can i take the voltage up higher that 1.6v and be safe? Whats safe voltage for this ram? The numbers go yellow at 1.61v and go red at 1.71v. Any advice would be great, thanks.
MB: MSI N980-G65
PSU: Antec 1000w
CPU-NB @ 2600
HT link @ 2000
