Hello
just trying to verify the steps & numbers for adjusting memory in BIOS to get memory @ 1600...
This is a new build, everything went together fine in POST... only issue was a "cd/dvd driver missing" in the begining of Windows 7 install.... this was resolved...
I'm not getting any errors or BSOD or problems.... I'm actually alittle disappointed @ the speed of this build(this is my 1st), I am happy that I didn't get any probs that I have read about... hell I was afraid it wouldn't even boot up(Murphy's law...Murphy been known to stay @ the house w/me)
If I understand this right, for this mobo, I would get into -
MB Intel Tweaker (MIT)
Set memory Clock to manual
scroll to Memory Clock - enter
Highlight x8.00 - enter
scroll to DRAM CONFIG - enter
scroll to DDR3 Timing Items - enter
set to Manual - enter
NOW, there is 3 columns... 1) is the manual settings of numbers, all are on AUTO... 2nd) is SPD settings of numbers & 3rd) is the AUTO settings of numbers... The SPD settings are the numbers that G.Skill has been recommending to use... Should I put all the SPD numbers in to the MANUAL CONFIG Column?
SPD Column #'s
CAS Lat-9
tRCD-9
tRP-9
tRAS-24
Command Tim-1T
TwTr Command Delay-5T
Write Recover Time-10T
Precharge Time- 5T
Row Cycle Time- 33T
RAS to RAS Delay-4T
This is the AUTO Columns #'s
CL-11
tRCD-11
tRP-11
tRAS-29
Command Time-AUTO
TwTr command Delay-6T
Write Recove Time- 12T
Precharge Time-6T
Row Cycle Time-40T
RAS to RAS Delay-5T
Thank You very much!!
I've ran the following test PRIOR to the manual config above
CPU-Z - Memory
TYPE-DDR3
Channels # - dual
Size - 4096MB
DC Mode - Unganged
NB Freq. - 2008.9 MHz
TIMINGS
DRAM Freq. - 669.6 MHz
FSB DRAM - 3:10
CL - 9
tRCD - 9
tRP - 9
tRAS - 24
tRC - 33
Command Rate - 1T
PC Wizard Cache & Mem Benchmark
Gen. info-
chipset ram type: DDR3-SDRAM PC3-10700 Dual
DIMM Type: DDR3-SDRAM PC3-10700
Bus Speed: 200.9 MHz
FSB Freq: 2008.8 MHz
Mem. Freq: 670 MHz
Mem. Bandwidth: 10713 MB/s
Latency: CL9
Memory Info
L1 Cache: 4 x 128 KB
L2 Cache: 4 x 512 KB
L3 Cache: 6144 KB
Total Mem. 4088 MB
SPD Column #'s
CAS Lat-9
tRCD-9
tRP-9
tRAS-24
Command Tim-1T
Precharge Time- 5T
Row Cycle Time- 33T
RAS to RAS Delay-4T
CL-11
tRCD-11
tRP-11
tRAS-29
Command Time-AUTO
Precharge Time-6T
Row Cycle Time-40T
RAS to RAS Delay-5T
CPU-Z - Memory
TYPE-DDR3
Channels # - dual
Size - 4096MB
DC Mode - Unganged
TIMINGS
FSB DRAM - 3:10
CL - 9
tRCD - 9
tRP - 9
tRAS - 24
tRC - 33
Command Rate - 1T
Gen. info-
Mem. Freq: 670 MHz
Latency: CL9
Memory Info
L3 Cache: 6144 KB
Total Mem. 4088 MB
