Hey guys,
I just recently bought 8 gigs of your F3-12800CL9-2GBNQ ram (4 sticks) and have installed them on my computer. I set the clock like this forum suggested at 9, 9, 9, 24 and the MHZ at 800 on the option for "Both". Everything seems to run great, had a few BSOD's first but then I tried each stick one by one, found them all to be good, reinstalled, put BIOS to default settings, and then re-edited the settings and it appeared to work fine. No BSOD's since.
My problem is, when I check out CPU-Z it says it's not running at said 800MHZ, in fact it says the max bandwidth is 667MHZ, which it's not running at either.
Here's a screenshot:
Did I not input the right settings?
My motherboard is an Asus M4A785TD-V EVO and my CPU is an AMD Phenom II X4 955.
Thanks in advance for the help!
