I have a EVGA 132-YW-E180-A1 motherboard and F3-12800CL9D-4GBNQ memory. I was wondering what the proper settings are to get full 1600 FSB to work with a Q9650 processor. I don't want to overclock yet, but assume I need a better setting than I'm currently using.
EVGA 790i FTW Digital Motherboard
Cpu fsb
I was looking for actually making the CPU FSB 1600. I changed it to FSB to 1600, multiplier to 8 so my CPU is at 3.2 Ghz. I made no voltage changes and rebooted. Is there any voltage changes I should apply with these settings. My windows 7 rating still shows the memory rating at 5.5. Everything else rates 7.8-7.9. The memory seems to be holding me back. I manually set all the timings to what was suggested. Unlinked the memory/CPU.
Download CPU-z and send me screen shots of the CPU and Memory settings so I can see if anything is set incorrectly. Although, it may simply be a glitch with the WEI. You can download Everest Ultimate to benchmark the memory and see where you compare with other systems.
Benchmark
Originally posted by GSKILL TECH View PostDownload CPU-z and send me screen shots of the CPU and Memory settings so I can see if anything is set incorrectly. Although, it may simply be a glitch with the WEI. You can download Everest Ultimate to benchmark the memory and see where you compare with other systems.
WEI doesn't always get true readings w/ AMD CPU/MCs, have seen where people have reloaded the OS after getting things stable and it go up.....also, score should increase w/ the 64 ver, which utilizes the RAM more efficiently
Bios problem
Originally posted by Tradesman View PostLet us know how it goes
