F3-12800CL9T-6GBNQ + x58a-ud3r
  • F3-12800CL9T-6GBNQ + x58a-ud3r
    Does the gskill tech know if this memory would work on this board?
    I already got the ram, but someone on another forum said it is not working properly..
    if more than 2gb gets installed.
    IT would sometimes recognize sometimes not.
    And also randomly BSOD..etc..
    http://www.hardforums.com/showthread.php?t=1493744
    Also would enabling xmp be useful/help?
    Why does it get turn off by default?
    Considering that it helps with RAM configuration.
    should work OK but would need some more info, i.e. CPU, speed, and preferably your BIOS settings.
      i7 920..
      Bios settings?
      I don't have the ud3r board yet..cos of the problem I read on that forum..
      I wanted to make sure the memory works before buying the board.
      http://gskill.us/forum/showthread.ph...2800CL9T-6GBNQ
      So would those settings allow it to work on the ud3r?
      Also can i still overclock?
      Btw if it doesn't work, can we RMA it for new memory that is compatable?
