F3-12800CL9D-4GBRL Bios Config problem
  • F3-12800CL9D-4GBRL Bios Config problem
    Hi G-Skill forum. Iam new here and this is my first post.
    Windows and memtest keep giving me memory errors. Any help pls?
    My PC:
    RAM: F3-12800CL9D-4GBRL
    MOTHER: Asus M4A78-E
    CPU: Phenom 2 945
    GPU: MSI ATI 5770
    Bios configuration:
    FSB Frequency: 200
    PCIE Frequency: 100
    Dram Frquency: 1600mhz
    tCL - 9
    tRCD -9
    tRP -9
    tRAS -24
    CR -2T
    DRAM Voltage 1.5
    CPU/NB Voltage: 1.4000
    HT Voltage: 1.50
    I read similar post here that where i get the bios configuration. But even thow it keep giving me error.
    Any help? whats wrong?
    Thanks Your Time
    Have you tried running Memtest on each stick individually? You may have a bad stick. Also make sure the sticks are firmly seated in the slots, the connectors are clean (i.e. no trace of dust or lint on them)...and on your set make the tRFC is about 127.5
      Ok i tryed trfc in 110 only 110 or 160 nothing between them. so 110 its closer to 127.5
      i removed both dim and intalled them again.
      For now there no error in test... hope it continue like this
      time will say
      Very Thanks
        If the problems return, next step would be to raise DRAM Voltage to 1.54 (Yes, it's safe) or kick the tRFC on up to 160 (in that order.
          Thank you! if any error apear i will let you know!
          Just one doubt, why my other PC-2 loads Game "Hon" faster than my other PC-1? -.- mine its better!
          (PC-1 its the one with DDR-3 Gskill RAM)
          My other PC:
          CPU: Core 2 duo E7400
          GPU: geforce 9800 GT
          RAM: Super Talent DDR-2 800 dual channel
          Mother: Asus P5kpl 1600
          It have no sence at all!! right? O_o
          PD: my new PC-1 have raid 0 ( 2 hdds), PC-2 have just 1 HDD with no raid...
            Could be a number of things...........
              About the game or just hardware and configuration?
              both have exactly same programs and good bios configuration.
                Prob the overall setup, while the AMD 945 is rate at 3.0 GHz, and the E7400 at 'only' 2.8, the E7400 is the stronger of the two and speedwise faster overall. Also the E7400 utilizes the NB Chipset for it's MC, while the AMD uses an onboard MC (which is a weak MC, AMD doesn't put a lot of money into R&D in order to keep pricing down). Most any Intel chip will outgun an AMD CPU from an even standpoint i.e. 3 GHz vs 3 GHz to even going down 2-4 tenths, i.e. 3 GHz vs 2.7 GHz. The Intel chips also have a broader/higher range available for OCing
                  interesting! thank you a lot !
                  0 problem with ram for now
                    Duro poco, recien crriendo el Memtest saltaron un par de errores de la Ram. Que co?o sera ! Tendre uno o ambo de los dim fallados?
                    Mas confiuguracion no se me ocurre
                      ok now testing with 160 and seems no error for now. time will say again, hope it work
                        Now running with TRFC 160 and non problem for 2 days. Maybe it just luck, we will see
