I have the G.SKILL Trident 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 2000
(PC3 16000) F3-16000CL9D-4GBTD memory and:
I7 860 2.8 Ghz
ASUS P7P55D EVO LGA 1156 Intel P55
Windows 7 64b
and having a problem to set up the 2000MHZ frequency in BIOS.
I have the BIOS 7/28/09 0209 MBEC-0027
I am able to set it up to maximum 1600. I tried to follow your
settings for i7 (see below), however my computer restarts during
loading the windows.
Please advise,
Remigiusz Zuber
Default F3-16000CL9D-4GBRH + ASUS P7P55D BIOS settings
Here are the settings for the G.Skill F3-16000CL9D-4GBRH + ASUS P7P55D
motherboards
We tested this motherboard at DDR3-2000 with 8GB at rated specs
without any issues. Went up to 2100 without any issues either.
Was able to get DDR3-2350+ with a different memory package
These tests were done on the Deluxe version with an i7 860 processor
(x 12 memory multiplier).
______________________________________
The settings may work for other DDR3-2000 memory packages as well or
other P55 motherboards.
i5 750 processor:
AI Overclock Tuner - Manual
CPU Ratio Setting - 14.0 for 2.80GHz
BCLK Frequency - 200
DRAM Frequency - DDR3-2000MHz
DRAM Voltage - 1.65V
CPU PLL Voltage - 1.90V
DRAM Timing Control (submenu)
CAS Latency - 9
RAS to CAS Delay - 9
RAS PRE Time - 9
RAS ACT Time - 27
DRAM Timing Mode - 1N
All others can be AUTO
i7 860 processor:
CPU Ratio Setting - 17.0 for 2.83GHz
BCLK Frequency - 167
DRAM Frequency - DDR3-2004MHz
CAS Latency - 9
RAS PRE Time - 9
RAS ACT Time - 27
Save and exit.
I7 860 2.8 Ghz
Windows 7 64b
Please advise,
Remigiusz Zuber
motherboards
i5 750 processor:
CAS Latency - 9
RAS PRE Time - 9
RAS ACT Time - 27
i7 860 processor:
CAS Latency - 9
RAS PRE Time - 9
RAS ACT Time - 27
Save and exit.
