I built a new system using G.Skill F3-10600CL8D-2GBHK and the mobo is a Gigabyte GA-MA770T-UD3P. I used Gigabytes memory compatiblity to get the memory however I've been having freezing issue where I have to restart the computer.
After checking the windows event log it says the lock up was due to the Vid Card getting stuck in an infinite loop. So after conctacting XFX about the issue they want me to check the system memory by removing a stick at a time.
On the box it lists the setting as 8-8-8-21 and 1.5v. So I set the BIOS manually however for the volts the lowest setting is 1.6v. Could this be the problem?
