My configuration:
Biostar T5 XE motherboard (Latest BIOS Update - 10/28/09)
G.Skill F3-12800CL7D-4GBRM
Intel Core i5-750
Thankfully, my build booted up smoothly by itself. However, when I checked to make sure the memory was running at 1600MHz, I found that it was running as 1333MHz. I've looked around the web and found that out this is because of the Core i5 limit. Also read that Intel doesn't recommend the voltage of the memory to be higher than 1.65v? I found this weird, because my BIOS doesn't even have 1.65v. It increases by 0.015v, starting from 1.6v. Please help me find the right setting, so I can utilize its full potential. Thanks again
Intel Core i5-750
