Both memtest and CPU-Z show the clock speed at 1033MhZ when it's supposed to be 2000MhZ.
I have an:
-ASUS P7P55D Pro
http://www.newegg.ca/Product/Product...82E16813131405
-G.SKILL Trident 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 2000
http://www.newegg.ca/Product/Product...82E16820231282
-Intel Core i5 2.66GhZ
http://www.newegg.ca/Product/Product...82E16819115215
My BIOS Settings in AI Tweaker are:
AI Overclock Tuner-Manual
CPU Ratio- 14
Speed Step- Enabled
Xtreme Phase-Auto
BCLK Frequency-200
PCIE Frequency-100
DRAM Frequency- 2000MhZ
Timings
CAS Latency - 9
RAS to CAS Delay - 9
RAS PRE Time - 9
RAS ACT Time - 27
Timing Mode 1N
CPU Voltage Mode- OFfset
DRAM Voltage- 1.6V
CPU PPL - 1.9V
Everything else is set to Auto.
I have an:
-ASUS P7P55D Pro
CPU Ratio- 14
Speed Step- Enabled
Xtreme Phase-Auto
BCLK Frequency-200
PCIE Frequency-100
Timings
CAS Latency - 9
RAS PRE Time - 9
RAS ACT Time - 27
Timing Mode 1N
DRAM Voltage- 1.6V
CPU PPL - 1.9V
