evga x58 sli le/i7 920/gskill 10666cl7t system
  • evga x58 sli le/i7 920/gskill 10666cl7t system
    I am trying to bring up this system. I can get everything working as long as I only use 1 stick, 2gig in only one of the 3 slots. Adding a 2nd stick the system will not boot to windows. Gets to were it should boot to windows and just does a mb reboot.
    Both the CPU and Mobo have been swapped out, and still get same behavior so its not the cpu or mobo.
    Only things left are memory (which is what I think) graphis card or power supply.
    Anyone have any suggestions?
    If it boots w/ 1 stick, tryrunning memtest on each stick to see if any errors. Additional things to look for, do you have the latest BIOS? Might also see if you can borrow and try different sticks, different GPU (graphics card) and/or PSU.
    Do you have the sticks in slots 1-3, if so might try 2-4. Might also check the vCore, the mobo tends to read low.
      Tradesman
      I ran windows memtest on each stick, they all passed. In previous board I flashed to latest BIOS, still had same problem. Dont have any way to borrow differnt GPU or sticks. I have a 500W power supply I could try but dont think thats enough watts.
      I have sticks in 1-3, could try 2-4.
      Are you suggesting to check VCore with a meter?
        Upped Vcore to 2.7, did not make a difference.
        sticks in 2-4 would not even get through POST.
        I think I will try different memory brand.
          Could you post your BIOS settings....you'll want Command Rate at 2T, 2N, tRFC at around 68, then the RAMs base timings and voltage...enter them all manually
            Tradesman, thanks for the help
            Mother Board ( EVGA X58 SLI LE 757)
            Drivers ( newest from evga site )
            Bios ( what came with MB, flashed previous board had same issue ) ( S61H )
            CPU ( i7 920 stepping 5 revision D0 )
            Memory ( G.SKILL Triple Channel 6gig Model F3-10666CL7T-6GBPK 7-7-7-18 )
            PSU ( Corsair tx650W )
            GPU ( Nvida g8400 PCI)
            Operating System ( Windows 7 64 Home premium)
            Frequency Control
            CPU Clock Ratio ( 21X Default )
            CPU Host Frequency (Mhz) ( 2785.9 this is core speed, no overclocking )
            MCH Strap ( Auto )
            CPU Uncore Frequency (2660Mhz)
            CPU Clock Skew ( 0 ps)
            Spread Spectrum ( Disabled)
            PCIE Frequency (Mhz) ( 100 )
            Memory Feature
            Memory Speed ( 1330 )
            Memory Control Setting ( Enabled )
            Memory Frequency ( 1330 ) ( 2:10 )
            Channel Interleave Setting ( 6 Way )
            Rank Interleave Setting ( 4 Way )
            Memory Low Gap ( Auto )
            tCL Setting ( 7 )
            tRCD Setting ( 7 )
            tRP Setting ( 7 )
            tRAS Setting ( 18 )
            tRFC Setting ( 68 )
            Command Rate ( 2t )
            Voltage Control
            EVGA VDroop Control ( Without VDroopxxx )
            CPU VCore ( 1.25 ) ( 1.45 )
            CPU VTT Voltage ( +.100 )
            CPU PLL VCore ( auto 1.8 )
            DIMM Voltage ( 1.6 )
            DIMM DQ Vref ( +0mV )
            QPI PLL VCore ( auto 1.1)
            IOH VCore ( auto 1.1 )
            IOH/ICH I/O Voltage ( Auto 1,5 )
            ICH VCore ( Auto 1.05 )
            CPU Feature
            Intel SpeedStep ( Disabled )
            Turbo Mode Function ( Enabled )
            CxE Function ( Disabled )
            Execute Disable Bit ( Enabled )
            Virtualization Technology ( Disabled )
            Intel HT Technology ( Enabled )
            Active Processor Cores ( All )
            QPI Control Settings ( Enabled )
            QPI Link Fast Mode ( Enabled )
            QPI Frequency Selection ( auto )
            OC Recorvery ( cant find )
            PnP/PCI PCI Express
            Maximum Payload Size ( didnt find ) no pci express cards
              are there 3 sticks shown after clearing CMOS?
              it seems there is problem with memory slot or memory controller to make it unable to run triple channel
              and oculd you tell us the complete model name?
              thanks
              G.S
