F3-12800cl9d-4gbnq & ga-ma785gmt-ud2h
  • F3-12800cl9d-4gbnq & ga-ma785gmt-ud2h
    I am experiencing a BSOD when I resume from sleep (Suspend to RAM)(S3) in Windows 7.
    Motherboard: Gigabyte GA-MA785GMT-UD2H Rev1.0 BIOS F2
    CPU: AMD Athalon X2 250
    Memory: 2 x F3-12800CL9D-4GBNQ running at 1600MHz
    OS: Windows 7 Enterprise 64 bit
    Any help would be greatly appreciated.
    Thanks.
    Is you X2 OCed? with the DRAM at 1600 you really need an OC on the CPU and some extra juice to keep the MC going (it's a bit on the weak side and doesn't wake up well.
      Not OC'd. Brand new build, want to use for HTPC.
      I tried all AUTO settings and for 1066MHz and still BSOD.
      Any help in the BIOS settings would be appreciated.
        Again, think you need to OC or just give up on the sleep mode. The CPU just doesn't have the coffee to wake up and start the sticks up
