G.SKILL Trident 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600
  • G.SKILL Trident 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600
    Hi
    Please help me to solve this problem.
    My Configuration:
    Main GA-EP45T-DS3R
    Bios Version: F3
    Memory: G.SKILL Trident 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL8D-4GBTD
    http://www.newegg.com/Product/Produc...82E16820231259
    Processor: Intel Core 2 Duo E8400 Wolfdale 3.0GHz LGA 775 65W Dual-Core Processor
    http://www.newegg.com/Product/Produc...82E16819115037
    VGA card: Gigabyte HD4670
    OS: Windows 7 Professional and Windows XP SP3.
    My computer is not stable as it crash regularly. I set the Bios as default except DDRAM Voltage = 1.5V (althougth it appear in PC Health Ststus
    DDRAM Voltage = 1.744V. I set the Ram Voltage to 1.74V, 1.72 or 1.7V then it reboot many times and can not start Windows).
    As I'm not good in Computer so I do not know how to set my board to run stable. I read many threads that guide to set parameters such as DDRAM TIMINGS, Command Rated, Vcore...But it make me very confuse.
    Please guide me to set these parameters correctly.
    Thank in advance,
    Hoang
    MB Intelligent Tweaker(M.I.T.)
    Robust Graphics Booster ...............: Auto
    CPU Clock Ratio ..........................:
    Fine CPU Clock Ratio.....................:.0
    CPU Frequency ...........................:
    Clock Chip Control
    Standard Clock Control
    CPU Host Clock Control..................: [Disabled]
    CPU Host Frequency (Mhz) ............: Mhz
    PCI Express Frequency (Mhz) .........:Auto
    C.I.A.2 .................................:[Disabled]
    Advanced Clock Control [Press Enter]
    CPU Clock Drive...........................:
    PCI Express Clock Drive.................:
    CPU Clock Skew (ps)....................:
    MCH Clock Skew (ps)...................:
    DRAM Performance Control
    Performance Enhance...................: [Turbo]
    Extreme Memory Profile (X.M.P.).....: [Disabled]
    (G)MCH Frequency Latch...............: [Auto]
    System Memory Multiplier ..............:
    Memory Frequency (Mhz) ..............:
    DRAM Timing Selectable ................: [Auto]
    Standard Timing Control
    CAS Latency Time........................
    tRCD .........................................
    tRP'...........................................
    tRAS..........................................
    Advanced Timing Control
    tRRD...........................................
    tWTR..........................................
    tWR............................................
    tRFC...........................................
    tRTP...........................................
    Command Rate (CMD) ....................:
    Driving Strength Profiles
    Driving Strength ............................
    Channel A
    Static tRead Value.........................:Auto
    tRD Phase0 Adjustment...................:Auto
    tRD Phase1 Adjustment...................:Auto
    tRD Phase2 Adjustment .................:Auto
    tRD Phase3 Adjustment..................:Auto
    Trd2rd(Different Rank)....................:Auto
    Twr2wr(Different Rank)...................:Auto
    Twr2rd(Different Rank)...................:Auto
    Trd2wr(Same/Diff Rank)..................:Auto
    Dimm1 Clock Skew Control...............:Auto ps
    Dimm2 Clock Skew Control...............:Auto ps
    Channel B
    Motherboard Voltage Control
    Voltage Type.………... Auto
    CPU
    CPU Vcore….……….........................: Auto
    CPU Termination…........................: Auto
    CPU PLL…………………......................: Auto
    CPU Referen.…………......................: Auto
    CPU Reference2………....................: Auto
    MCH/ICH
    MCH Core……………...........................: Auto
    MCH Reference….…….......................: Auto
    MCH/DRAM Ref.…...........................: Auto
    ICH I/O………………............................: Auto
    ICH Core…………...…….......................: Auto
    DRAM
    DRAM Voltage ……...........................: 1.500V
    DRAM Termination .…......................: Auto
    Channel A Reference .......................: Auto
    Channel B Reference .......................: Auto
    Advanced Settings
    Limit CPUID Max. to 3.....................: [Disabled]
    No-Execute Memory Protect............: [Enabled]
    CPU Enhanced Halt (C1E)................: [Disabled]
    C2/C2E State Support....................: [Disabled]
    x C4/C4E State Support..................: [Disabled]
    CPU Thermal Monitor 2(TM2) ...........: [Enabled]
    CPU EIST Function.........................: [Disabled]
    Virtualization Technology................: [Disabled]
    Integrated Peripherals
    Legacy USB Storage Detect ..............[Disabled]
    USB__________________
    You'll want to manually set your base timings to 8-8-8-21, DRAM voltage to 1.6, Command Rate to 2T (or 2N depending on how the BIOS displays it) and you tRFC to appr 68.
      Thanks alot. I will check whether it could get stable and post updated with performance.
        Hi Tradesman
        I set parameters as your suggest (base timings to 8-8-8-21, DRAM voltage to 1.6, Command Rate to 2, tRFC = 68) and now my computer run with out any trouble. It's amazing, I show you the result from EVEREST test
        Is this ok for an DDR3 12800? May I have an increase in performance? If yes, please teach me what should I adjust?
        Thanks you so much.
        Hoang
          You can try and increase the performance....but to be honest, unless your looking for benchmark increases (bragging rights) it's probably not worth it..........UNLESS...you have some time and like to play (don't we all?)...if that's true, you'll want to document your current settings so you have a fallback position to go to if you have a failure. Next you can try playing with the base timings, your currently at 8-8-8-21, so you could try 7-8-8-24 or 8-7-7-21, etc the lower (or tighter) the numbers, will show an increase in performance....but, it's not likely to be anything you will 'see' or notice, except in benchmark scores.
          Don't want to burst any bubbles, but if your thinking a noticible increase in performance you probably won't see it
            Hi Tradesman
            Sorry for bothering you again. I was a bit early to say that my system was stable and was busy to ask for your help since last time. My system still crash sometimes, it not too much but sometimes it happen when I making video or burning disc.
            Could u please give me some advices to clear this matter. I re-install my system some times but it did not work. I did keep my configuration as your suggest last time (base timings 8-8-8-21, DRAM voltage to 1.6, Command Rate to 2, tRFC = 68) and my OS is Window 7 Ultimate 64 bit.
            Thank you so much for your help.
            Hoang
              I check with soft Whocrashed and it give conclusion as below:
              Analysis
              Crash dump directory: C:\Windows\Minidump
              Crash dumps are enabled on your computer.
              On Fri 19/02/2010 12:51:36 CH your computer crashed
              This was likely caused by the following module: ntoskrnl.exe
              Bugcheck code: 0x1A (0x5003, 0xFFFFF90000812000, 0x15CE, 0xFFFFF900C217E009)
              Error: MEMORY_MANAGEMENT
              Dump file: C:\Windows\Minidump\021910-15272-01.dmp
              file path: C:\Windows\system32\ntoskrnl.exe
              product: Microsoft? Windows? Operating System
              company: Microsoft Corporation
              description: NT Kernel & System
              The crash took place in a standard Microsoft module. Your system configuration may be incorrect, possibly the culprit may be another driver on your system which cannot be identified at this time.
              On Tue 16/02/2010 4:05:51 CH your computer crashed
              Bugcheck code: 0x1A (0x5003, 0xFFFFF780C0000000, 0x2ABE, 0xFFFFF9800BF8AC09)
              Dump file: C:\Windows\Minidump\021610-16146-01.dmp
              On Sat 30/01/2010 1:07:54 CH your computer crashed
              Bugcheck code: 0x1A (0x5003, 0xFFFFF780C0000000, 0x1ADE, 0xFFFFF9800145B009)
              Dump file: C:\Windows\Minidump\013010-15194-01.dmp
              Conclusion
              3 crash dumps have been found and analyzed. Note that it's not always possible to state with certainty whether a reported driver is really responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
                Any one can help me? Right now I can not use my desktop to do any work because of it's not stable and alway appear BOD screen.
                I set M.I.T as suggest from Tradesman, any wrong from my setting or the Ram need to RMA? Thanks for your help. I set as below:
                Performance Enhance...................: [Standard]
                System Memory Multiplier ..............: [Auto]
                Memory Frequency (Mhz) ..............: [Auto]
                DRAM Timing Selectable ................: [Manual]
                CAS Latency Time........................8
                tRCD .........................................8
                tRP'...........................................8
                tRAS..........................................21
                tRRD...........................................Aut o
                tWTR..........................................Auto
                tWR............................................Aut o
                tRFC...........................................68
                tRTP...........................................Aut o
                Command Rate (CMD) ....................:2
                Channel A
                Static tRead Value.........................:Auto (Need to specify or not)
                Channel B
                Voltage Type.???... Auto
                CPU
                CPU Vcore?.???.........................: Auto (Need to specify or not)
                CPU Termination?........................: Auto (Need to specify or not)
                CPU PLL???????......................: Auto
                CPU Referen.????......................: Auto
                MCH/ICH
                MCH Core?????...........................: Auto (Need to specify or not)
                MCH Reference?.??.......................: Auto (Need to specify or not)
                MCH/DRAM Ref.?...........................: Auto (Need to specify or not)
                ICH I/O??????............................: Auto (Need to specify or not)
                ICH Core????...??.......................: Auto (Need to specify or not)
                DRAM
                DRAM Voltage ??...........................: 1.500V (1.600V)
                DRAM Termination .?......................: Auto (Need to specify or not) (I did set 1.600V)
                Channel A Reference .......................: Auto (Need to specify or not) (I did set 0.800V)
                  tRFC AUTO
                  DRAM Voltage 1.65V
                  Other than that, everything seems just fine. Try testing each one individually to determine whether one may be defective.
                    Thank for your help.
                    I set number as you give above with all other parameters : Auto
                    tRFC...........................................Aut o
                    DRAM
                    DRAM Voltage ……...........................: 1.640 V and 1.660 V (because do not have 1.65 V)
                    As I set DRAM Voltage to 1.64 V or 1.66 V, Windows work only for few minutes or even not pass through the first starting window. After few reboot with this setting (after appear BOD said about memory problem) then it even can not reboot system with sound "beep beep beep". I have to take out 1 stick and reduce DRAM Voltage to 1.6V for it to boot again. I tried test each stick individually with DRAM Voltage at 1.6V (at both slot) by Windows 7 Utility and it pass through the standard test. Now I can use only 1 set 2Gb with DRAM Voltage at 1.6 V. Please help me on what parameters need to change.
                    Thank you.
                      Is that the latest BIOS for the motherboard?
                        Yes, I use F4C version and it is the latest Bios version from Manufacturer.
                        Thank you.
                          Did you test each module to make sure they are all working fine?
                            Yes I did. I tested each of sticks individually at both slots with Windows 7 Ultility (standard mode). And all sticks pass without any problem.
                            Here is information I get from Everest when I use 2 DRAM at 1.6V
                            Chipset Properties:
                            Motherboard Chipset Intel Eaglelake P45
                            Memory Timings 8-8-8-21 (CL-RCD-RP-RAS)
                            Command Rate (CR) 2T
                            DIMM1: G Skill F3-12800CL8-2GBTD 2 GB DDR3-1333 DDR3 SDRAM (9-9-9-24 @ 666 MHz) (8-8-8-22 @ 592 MHz) (7-7-7-19 @ 518 MHz) (6-6-6-16 @ 444 MHz)
                            DIMM3: G Skill F3-12800CL8-2GBTD 2 GB DDR3-1333 DDR3 SDRAM (9-9-9-24 @ 666 MHz) (8-8-8-22 @ 592 MHz) (7-7-7-19 @ 518 MHz) (6-6-6-16 @ 444 MHz)
                            BIOS Properties:
                            System BIOS Date 09/03/09
                            Video BIOS Date 03/09/09
                            Award BIOS Type Award Modular BIOS v6.00PG
                            Award BIOS Message EP45T-DS3R F4c
                            DMI BIOS Version F4c
                            Voltage Values:
                            CPU Core 1.07 V
                            +3.3 V 3.38 V
                            +12 V 12.30 V
                            +5 V Standby 5.21 V
                            VBAT Battery 3.12 V
                            DIMM 1.58 V
                            [ DIMM1: G Skill F3-12800CL8-2GBTD ]
                            Memory Module Properties:
                            Module Name G Skill F3-12800CL8-2GBTD
                            Serial Number None
                            Module Size 2 GB (2 ranks, 8 banks)
                            Module Type Unbuffered DIMM
                            Memory Type DDR3 SDRAM
                            Memory Speed DDR3-1333 (667 MHz)
                            Module Width 64 bit
                            Error Detection Method None
                            DRAM Manufacturer G Skill
                            Memory Timings:
                            @ 666 MHz 9-9-9-24 (CL-RCD-RP-RAS) / 33-74-4-10-5-5 (RC-RFC-RRD-WR-WTR-RTP)
                            @ 592 MHz 8-8-8-22 (CL-RCD-RP-RAS) / 30-66-4-9-5-5 (RC-RFC-RRD-WR-WTR-RTP)
                            @ 518 MHz 7-7-7-19 (CL-RCD-RP-RAS) / 26-58-4-8-4-4 (RC-RFC-RRD-WR-WTR-RTP)
                            @ 444 MHz 6-6-6-16 (CL-RCD-RP-RAS) / 22-49-3-7-4-4 (RC-RFC-RRD-WR-WTR-RTP)
                            Extreme Memory Profile:
                            Profile Name Enthusiast (Certified)
                            Memory Speed DDR3-1600 (800 MHz)
                            Voltage 1.60 V
                            @ 800 MHz 8-8-8-21 (CL-RCD-RP-RAS) / 30-60-2-6-10-6-6 (RC-RFC-CR-RRD-WR-WTR-RTP)
                            Memory Module Features:
                            Auto Self Refresh Supported
                            Extended Temperature Range Supported
                            Extended Temperature Refresh Rate Not Supported
                            On-Die Thermal Sensor Readout Not Supported
                            Memory Module Manufacturer:
                            Company Name G.Skill International Enterprise
                            Product Information http://www.gskill.com/products.php
                            [ DIMM3: G Skill F3-12800CL8-2GBTD ]
                            Serial Number None
                            Module Width 64 bit
                            Memory Timings:
                            Voltage 1.60 V
                            Memory Timings:
                            CAS Latency (CL) 8T
                            RAS To CAS Delay (tRCD) 8T
                            RAS Precharge (tRP) 8T
                            RAS Active Time (tRAS) 21T
                            Row Refresh Cycle Time (tRFC) 74T
                            RAS To RAS Delay (tRRD) 4T
                            Write Recovery Time (tWR) 20T
                            Read To Read Delay (tRTR) Same Rank: 4T, Different Rank: 9T
                            Read To Write Delay (tRTW) 9T
                            Write To Read Delay (tWTR) Same Rank: 15T, Different Rank: 8T
                            Write To Write Delay (tWTW) Same Rank: 4T, Different Rank: 7T
                            Read To Precharge Delay (tRTP) 7T
                            Write To Precharge Delay (tWTP) 20T
                            Precharge To Precharge Delay (tPTP) 1T
                            Refresh Period (tREF) 5200T
                            DRAM Read ODT 3T
                            DRAM Write ODT 7T
                            MCH Read ODT 8T
                            Performance Level 7
                            Read Delay Phase Adjust Neutral
                            DIMM1 Clock Fine Delay 0T
                            DIMM2 Clock Fine Delay 6T
                            DIMM3 Clock Fine Delay 12T
                            DIMM4 Clock Fine Delay 6T
                            Actually, I don't understand these number mean. So please help me to have best parameters for this Ram and I will adjust follow it.
                            Thank you.
                            Hoang.
                              Don't adjust anything you don't know. Simply leave to AUTO.
                              The main problem I see is Write Recovery Time (tWR) 20T. It should be 12T.
