Configuration:
Motherboard: ASUS P7P55D Pro
BIOS Ver: 915
RAM: (4 dimms) #F3-10666CL8-2GBHK
CPU: Intel, Lynnfield, Core i7 860
I have the same symptoms as several others.
The computer boots properly with 2 dimms installed either as dual or single channel.
Runs fine, never stumbles. If all 4 slots are occupied, it will "blue screen" at a cold boot.
I remove the dimms in slots A2&B2, reboot with no problem, shut-down Win-7 immediately, re-install the dimms in slots A2&B2, reboot and run without problem for the rest of the day.
I recently flashed the latest BIOS (#915). Set the AI Tuner to: X.M.P. and selected the single
profile offered (8,8,8,21). The computer ran properly all day with 8GB installed at those settings . I rebooted uneventfully several times through the day. I thought the problem had been solved with the new BIOS. But, when "cold" booted the next morning, it "blue-screened". I have tried several combinations of settings.
The computer always reboots with the 8GB and runs without incident for the rest of the day.
The next morning it will always crash at the cold boot. I repeat the sequence in the first paragraph and continue.
Not a convenient start to the day.
It would appear that several other manufacturers/vendors of DDR3 desktop RAM are experiencing similar problems.
Perhaps the problem lies with Intel's combination of the P55 chipset with the i5/i7 CPu and not the RAM manufacturers.
Have any settings been discovered that will allow the ASUS P7P55D_PRO + F3-10666CL8-2GBHK DDR3-1333 RAM to cold boot reliably and maintain a stable 8Gb?
Any suggestions will be appreciated. And, apologies for the long post!
Thanks in advance,
David
BIOS Ver: 915
Thanks in advance,
David
