When I first built this machine (specs below), I used only 4GB ram (2 sticks), but have recently upgraded to 8GB (4 sticks). When the CPU and memory are at stock "auto" settings (board put it at 9-9-9-24 at 1333mhz-1.6v) I get frequent BSODs after the increase to 8GB. When I was using only 4gb I manually set ram at 8-8-8-21 (all other settings on auto-1.6v) and did not have this problem-machine was very stable. I have tried increasing Ram, NB and SB/HT voltages and even relaxing the timings looser than 9-9-9-24, but continue to get the frequent BSOD's.
I have finally resorted to manually dropping the ram back to 1066mhz and now the board's auto settings currently show the ram at 8-8-8-20 at 1066mhz. My machine has been stable now for 3 days.
I have run memtest and windows memory checker and neither shows any problem with the memory. Random BSOD's continue and Prime 95 and OCCT will either drop a core due to an error or BSOD if the ram is running 1333. As mentioned above, if I drop the timing back to 1066mhz I can run P95 or OCCT without error and my random BSOD's stop.
I am starting to think that the for some reason the memory controller can't handle the 8GB of ram unless I really slow it down to 1066.
What do I need to do to get my machine stable at 1333 with 8GB?
Phenom II x3 720 BE (3 cores and not overclocked or over-volted)
8GB GSkill F3-10666CL8D-4GBHK (2 matched pairs)
Gigabyte GA-MA790FXT-UD5P with F6 Bios
