Hello good people!
I`m a newbie here, and would greatly appreciate if you would share your wisdom with me.
I`m planning to upgrade my old build with 2x4GB DDR3 kit, but not sure if the ones I have my eyes on are compatible with it.
My build:
M4A88TD-M EVO
Phenom II X2 555 (+2 cores unlocked goes up to 3.8-3.9Ghz)
I know these kits are a bit overkill and won`t reach their full potential, but I`m planning to run them with timings tight as possible.
I just want to know if any of these would work in harmony with the other parts?
Kits:
F3-12800CL9D-8GBXL
F3-14900CL9D-8GBXL
F3-17000CL11D-8GBXL
F3-2400C11D-8GAB
My build:
M4A88TD-M EVO
Kits:
F3-12800CL9D-8GBXL
F3-14900CL9D-8GBXL
F3-17000CL11D-8GBXL
F3-2400C11D-8GAB
Anyway I`ll keep looking.
