Asus P5KC and DDR3 2000Mhz PC16000 4GB G.Skill Ripjaws 4GBRH
  • #16
    try raising ROW REFRESH RECYCLE TIME to 68
    • #17
      The higher settings won't boot because your memory timings are all wrong. They are currently 5-5-5-15 when they should be 9-9-9-27. Set them to 9-9-9-27 and you will be able to run 1600 at least.
      You will need to take pictures of BIOS, host them, then insert link here to show us.
      • #18
        "These are the settings m @.If i try higher settings pc doesnt boot,from 1130 next settings are 1254 then 1397 etcetc"
        Now m @ 1130 5-5-5-15
        Just because i cant reach anything higher then that,i would like to know infact if theres a way to grab bios screens(course i really doubt) because with my mobile phone the picture would be for sure a real mess....
        What bout the fsb strap i never quite understood what thats for...
        • #19
          Instead of 5-5-5-15, you need to change them to 9-9-9-27 in order to increase memory frequency.
