First time here, please forgive my English and forgive my novice knowledge, i am not hardware expert.
I surfed the forum, searched and read many threads, but the more i read and more i feel lost !
So here we go :
I have 2X4GB ( F3-12800CL9D-8GBXL ) installed on ASUS P8Z68-V Pro/Gen3 with Intel i7-2600K, now due to the quarantine i have to move to use my home PC and 8gb is barely allowing my software to function, with Android studio with one Android emulator and Chrome and memory usage is already 9gb, so i need at least extra 4gb.
Everything is working just fine, i don't overclock and not planning to.
My questions is :
1) What sort of problems to expect in adding two extra modules of the same model F3-12800CL9D-8GBXL ?
2) Will be there compatibility issue that can't worked around with 4 of those modules ? (higher temperature , Windows BSOD ..etc..)
3) How much speed degradation should i expect ? ( up to %10-%15 is OK for me ) my concern is about working right without show stopper, speed is last on my list.
4) In case everything is OK with the above questions, is it possible to add different modules ( not exact model), like can i add 2 modules from F3-12800CL9D-4GBRL? and in this case : what is the probability of making them works in stable manner by setting the bios timing manually?
5) How to test system stability ? what software to use ?
Thank you in advance.
So here we go :
My questions is :
