Model of the motherboard: Gigabyte GA-MA770T-UD3P
Model of the memory: F3-10666CL8D-4GBRM
Model of the CPU: AMD Athlon II X4 620
After searching the forums and trying all the answers I found, I cannot get my system to run stable at all. After 5-10min it will just lock up and I will have to reboot, this happens on both the auto and manual settings that I have found here.
As a sample this is the auto settings:
Memory Clock: x6.66 1333Mhz
Unganged
CAS 9t
RAS 9t
Row Pre 9t
Min RAS 21t
1t/2t auto
TwTr 5t
Trfc0,1 110ns
Write Rec 10t
Precharge 5t
Row Cyc 33t
RAS to RAS 4t
In manual the most stable I have found is
Unganged
CAS 8t
RAS 8t
Row Pre 8t
Min RAS 21t
1t/2t 1t
TwTr 5t
Trfc0,1 160ns
Write Rec 10t
Precharge 5t
Row Cyc 34t
RAS to RAS 4t
DRAM voltage 1.65v
DDR VTT 1.1v
NB Voltage 1.2v
SB/HT 1.4v
I updated the BIOS to the latest revision.
Any help would be greatly appreciated.
Unganged
CAS 9t
RAS 9t
Row Pre 9t
Min RAS 21t
1t/2t auto
TwTr 5t
Trfc0,1 110ns
Write Rec 10t
Precharge 5t
Row Cyc 33t
RAS to RAS 4t
Unganged
CAS 8t
RAS 8t
Row Pre 8t
Min RAS 21t
1t/2t 1t
TwTr 5t
Trfc0,1 160ns
Write Rec 10t
Precharge 5t
Row Cyc 34t
RAS to RAS 4t
DRAM voltage 1.65v
DDR VTT 1.1v
NB Voltage 1.2v
SB/HT 1.4v
