I have been trying to run my new UD4P motherboard with 12gb of G.Skill memory (2 x F3-10666CL9T-6GBNQ) using default bios settings and the latest bios revision.
However, running all 6 modules results in errors and one of the modules becoming permanently faulty.
Gigabyte tells me that not all brands of RAM work equally well in these boards. However, they say modules are not expected to be permanently damaged like mine appears to be.
I am able to run 4x2gb (of my remaining working modules) stably in a 3-channel configuration without any problems so I am wondering if the problem is moterhboard-related rather than RAM related. Perhaps a faulty slot?
Has anyone got experience with running 12gb of this type of RAM in a GA-EX58-UD4P motherboard? Are permanently damaged modules a known result of running six of these in one board?
Any advice on tests to figure out if the problem is RAM related or motherboard related (without having to buy another 6 modules of a different RAM...)
Cheers
Cheers
