I built my PC about nine months ago and over the last few months (mostly since upgrading to Windows 10) I have been getting a LOT of BSODs focused around Memory_Management. There have been others, but mostly MM blue screens. Sometimes these crashes happen in quick succession and other times the PC can run all day with no issues. Lately, the BSODs have been happening much more frequently...
I finally got off my backside and ran memtests. Here are my specs:
CPU: i7-4790k
MB: Gigabyte GA-Z97X-Gaming 5
RAM: F3-12800CL10D-16GBXL
Oddly enough, I ran four tests. The first test Stick1 in DIMM Slot 1 (MB Slot 1) gave me a lot of errors. I will attach the results here.
The second test, I swapped out Stick1 for Stick2 in DIMM Slot 1 (MB Slot 1) and it came up clean. No errors.
The third test, I kept Stick 2 in DIMM Slot 1 (MB Slot 1) and added Stick 1 to DIMM Slot 2 (MB Slot 3) and it came up clean as well. No errors.
The fourth test, I removed Stick 2 and kept Stick 1 in DIMM Slot 2 (MB Slot 3) and it gave me errors again. I will attach the results here.
So, should I RMA the kit? Please let me know. Thank you for your time.
Thadar
Edit: Well, I sent in an RMA. Hope I get a response soon with the number.
CPU: i7-4790k
Thadar
