Would this RAM module,
F3-10666CL9D-4GBNQ
be compatible with
foxconn G33m-02
which is a modified version of Dell Vostro 200. The BIOS is 1.0.15, and it supports the current RAID HDD. The OS is Vista x64.
I am assuming the timing of 9-9-9 would guarantee stability of & compatibility with the system than 8-8-8, correct?
Thanks for your support.
F3-10666CL9D-4GBNQ
be compatible with
foxconn G33m-02
