M4A78T-E X [Sniper] F3-17000CL11D-8GBSR
  • #16
    I think i'll try change the motherboard....
    In order to really solve this problem... can you guys please make a sugestion for a motherboard to buy?
    Any particular model that works fine with this memory modules...
    Thanks in advance...
    • #17
      Here is a great motherboard:
      http://www.newegg.com/Product/Produc...82E16813131851
      You can update CPU and improve performance in the future if you would like.
      • #18
        The Asus is really good but a little expensive here in brazil.... what about this one?
        MB GigaByte p/ AMD GA-970A-D3P AM3/AM3+
