You will see specs from images, you will see missing ram.
Windows 7 and BIOS both can detect all sticks but Windows will only use 3.
I'm going to test each stick separately but before I do, what do you think the problem is?
ALSO, with this cpu i think at the stock Freq. the max clocking is 1600. Am I right? Because I haven't been able to clock over 1600 without the mobo beeping three or four times (not sure what that meant)
Does anyone have a link for overclocking on a fx-8350? or advice?
SPECS:
CURRENT RAM STATUS:
CPU:
MOBO:
ASrock 990fx extreme3 BIOS: 2.5
EXACT TIMING OF EACH STICK:
RAM
Memory slots
Total memory slots 4
Used memory slots 4
Free memory slots 0
Memory
Type DDR3
Size 16384 MBytes
Channels # Dual
DRAM Frequency 573.3 MHz
CAS# Latency (CL) 7 clocks
RAS# to CAS# Delay (tRCD) 7 clocks
RAS# Precharge (tRP) 7 clocks
Cycle Time (tRAS) 19 clocks
Bank Cycle Time (tRC) 26 clocks
Physical Memory
Memory Usage 21 %
Total Physical 12 GB
Available Physical 9.34 GB
Total Virtual 24 GB
Available Virtual 21 GB
SPD
Number Of SPD Modules 4
Slot #1
Type DDR3
Size 4096 MBytes
Manufacturer G.Skill
Max Bandwidth PC3-12800 (800 MHz)
Part Number F3-14900CL9-4GBXL
SPD Ext. EPP
XMP--2
Frequency
XMP--2
Frequency
JEDEC #6
Frequency 838.1 MHz
CAS# Latency 11.0
RAS# To CAS# 11
RAS# Precharge 11
tRAS 30
tRC 41
Voltage 1.500 V
ETC.....
SPECS:
CURRENT RAM STATUS:
CPU:
MOBO:
RAM
Memory slots
Used memory slots 4
Free memory slots 0
Memory
Type DDR3
Size 16384 MBytes
Channels # Dual
Physical Memory
Memory Usage 21 %
Total Virtual 24 GB
SPD
Slot #1
Type DDR3
Size 4096 MBytes
SPD Ext. EPP
XMP--2
Frequency
XMP--2
Frequency
JEDEC #6
Frequency 838.1 MHz
CAS# Latency 11.0
RAS# To CAS# 11
RAS# Precharge 11
tRAS 30
tRC 41
Voltage 1.500 V
ETC.....
