If you were going to buy pc 1600 ram with the intention of trying to overclock it which is your best bet... I know every kit is different, just wondering if there is one set more likely than the others.
F3-12800CL8Q-16GBZH (black ripjaws, H ending number or does the 8c make it less likely?)
F3-12800CL9Q-16GBSR (c9 snipers)
F3-12800CL9Q-16GBXL (red ripjaws with 9latency, and L ending)
F3-1600C7D-16GTX (tridents, 2x 8gb instead of 4x4 for the rest)
also would going for 2x8 be easier or tougher to oc than 4x4 setup?
considering building another computer as a buddy has offered me about $400 more than I spent on the one I just built... can get a bit more memory for little more money, figure spend the rest on a processor/vid card upgrade.
