Computer doesn't start when using XMP profile with memory speed at DDR3-2133 and 4 memory modules installed. Tested one memory module at the time and it works fine. Also tried 4 memory modules using XMP profile with memory speed at DDR3-1866 (the next lower sped setting) and it works fine.
I had this computer running fine using XMP profile with memory speed at DDR3-2133 with 4 F3-17000CL9Q-16GBXM memory modules.
Any ideas as to what I can do to make this memory modules work?
