I'm putting my building together:
Asus P8Z77-V Deluxe motherboard (not ROG)
Intel i7-3770K Ivy Bridge CPU
G.Skill TridentX F3-2400C10D-16GTX memory (DDR3-2400 PC3-19200 8MB x 2)
When I power up the build, the Asus BIOS reports:
EZ Mode > Total Memory: 16384 MB (DDR3 1333 MHz)
Adv Mode > Main > Memory Frequency: 1333 MHz
Adv Mode > AI Tweaker > Target DRAM Speed: 1333 MHz
Adv Mode > AI Overclock Tuner: Auto
Adv Mode > Memory Frequency: Auto
I'm not into gaming or overclocking, but I would like the memory to be set to its rated speed of DDR3-2400.
I am also a good bit confused on what XMP is all about.
Is there a quick tutorial as to what I need to do in order to accomplish that? Or if someone could provide a quick explanation, I would be grateful. I saw one post that had a ROG Bios, but this is the regular bios from the P8Z77-V Deluxe.
Thank you.
Thank you.
