Hi everybody, first time here (even if I'm at my forth G.Skill ram kit)
I recently upgraded my pc from a X58 platform (good old years, with the Perfect Storm 2000 @Elpida Hyper) to a Z77 and i7 3770K with the following spesc:
CPU = Intel Core i7-3770K @4.6Ghz (1.224-1.236v)
MB = Gigabyte Z77X-UP5 TH (F12a with latest mod)
GPU= Gigabyte Amd 7950OC WF3
RAM = G.Skill F32400C9D-8GTXD PC3-19200 (4GBx2)
PSU = Cooler Master Silent Pro M 850W
PRIMARY HD = Ocz Vector
After some weeks with a (borrowed) kit of Tactical Tracer 1866 I finally upgraded to the ram kit as above (Tridentx), it's been quite a month, and I descover recently that just I can't get 100% stable with more than 30' of the latest prime95 (v.2.79)
All at default Xmp profiles, i.e. 2400Mhz cl 9-11-11-31-2T (1T) and 1.62-1.65v
I thought I was stable with 20 runs of Linx but this prime 95 it's a different story
Tried lots of things (including the vtt and imc volt increases) and bios versions, here's an example:
http://www.overclock.net/t/1285652/o...#post_20071212
But maybe they doesn't matter anymore except for the last days tests
As suggested I did test my ram at default cpu speed with the Xmp Profile 1 and 1.65v manually (the Xmp sets a higher, 1.680v) and it was finally ok, managed to get stable, no errors whatsoever for more than 2h:
http://cdn.overclock.net/8/8e/8e9ce43f_Clipboard01.jpeg
http://www.overclock.net/t/1285652/o...#post_20077731
http://www.overclock.net/t/1285652/o...#post_20091381
