Hi guys, I am currently using eVGA x58 SLI e758 (the very first x59 eVGA put out) with 3x2GB G.Skill RAM (I can't remember which model).
I am using the board with Core i7 920 C-0 stepping. It is currently running at 3.7Ghz (20 x 185).
I am looking to upgrade the RAM to 3x8GB and was wondering if F3-1600C9Q-32GSR (DDR3-1600 32GB (8GB*4) CL9 Sniper GSkill SR) will work with the board when I only use 3 of the 4 memory sticks.
XMP probably does not work with this board, correct? So, I am assuming that I would need to manually fine tune the timing and all?
Thx~
Thx~
