asus rampage 3 xtreme with F3-16000CL9T-12GBTDD (4Gx3)
  • asus rampage 3 xtreme with F3-16000CL9T-12GBTDD (4Gx3)
    Hi!
    My pc : (little updated)
    Intel core i7 x980 @ 3.33GHz
    disk: OCZ RevoDrive 3 X2 PCIe 240GB,
    disk: 2x 500gb hybrid disk
    ram: G.Skill 6*4 (24gb) F3-16000CL9T-12GBTDD (4Gx3)
    video card: Radeon 6990 4gb
    motherboard: ASUS Rampage III extreme
    sound card: Sound Blaster X-Fi Titanium Fatal1ty Professional
    power Supply: Platimax 1500W
    mouse: Razer Mamba
    keyboard: Razer Arctosa
    monitor : Dell u3011
    Now i got problem with my G.Skill 6*4 (24gb) F3-16000CL9T i got this ram now for a 3 years and still not runing on a 2000. I rune them on default 1330. For this rams i give 1100€ (3years ago) I would like that you can pleas tell me the QPI/DRAM, core voltage, CAS Latency that i can get stabel rams on 2000 . All 24GB rams are deceted and works in windows ther is no problem.
    BIOS: up to 1502
    Now i need help to stabel rams if you can test motherboard+cpu+rams if you dont have that components pleas let me know i can send you mine because i would like that rams to work on 2000 (STABEL)
    HELP
    thanks in advance
    exibo
    ps: ther is my old post: http://www.gskill.us/forum/showthread.php?t=6594 (i try not stabel) tested on 1.20-1.65
    http://shrani.si/f/2L/lR/20R2ShUn/screenshot1.png
    Can you post up your current BIOS settings (primarily DRAM timings (base and Advanced) as well as system voltages
      I holp that you can tell me how to make at least 12gb stabel on 2000 24gb rams wont work on rampage 3 extreme prime85 found 65000+ errors with 24 rams if ther are on default 1333 or O.C.
      12gbs ram are on 9-9-9-24 read pretime is 7 (prime95 50 errors)
      if i give 12gb 3X4GB on triple chanel they are not stabeled 1.65v errors
      i got now only 8gb on motherboard 9-9-9-24 1.55v pretime 7 and stabel what i need to do for 12gb to get stabeld???
      Using google translate
        What is your QPI/DRAM Core Voltage?
        You need the precise voltage for a perfectly stable system.
          QPI/DRAM Core Voltage 1.65v
            Try DRAM BUS voltage 1.65, QPI/DRAM voltage 1.25
              Tman sorry for so late replay , still not working as it should ram crash When testing 1sec error/s,
              EXP on tryed like you say but nothing using a program OCCT for ram testing and can not get stable rams :S :S
