I'm looking at putting together a system with an AMD FX-8350 and 4x 8GB sticks of DDR3 in an ASRock 990FX Extreme9 mobo:
http://www.asrock.com/mb/AMD/990FX%2...e9/?cat=Memory
Although it says it will take up to 64GB with recent BIOS updates, at this point, I'll stick with 32GB, since I can't seem to find 16GB sticks and I'm afraid they'd be a bit overkill, coming from a Q6600 with only 4GB of DDR2.
The gskill.com ram configurator (as well as newegg's) gives a bunch of possibilities, but nothing on the ASRock QVL (above) shows anything using 8gb sticks, let alone 16gb ones.
Do I want a set of 4 quad channel, a set of two pairs of dual channel, or 4 single channel? And at what speed and timings?
I'm looking to run Linux and sometimes do overclocking, but most of the time, I just want something stable that I can play a few games on and run VMs. Tend to keep my systems running 24x7.
What's the difference between the different named types of G.SKILL? Even on gskill.com, it only lists by speed and doesn't seem to point out what differentiates the different named types (might be a good thing to put in a FAQ). Ares seems like it might be lower end, but some of the CL are fairly decent. TridentX seems to be the best, since that is what most of the recent news releases have been about. Going through these threads, Ripjaws seems to be an older version, with RipjawsX and RipjawsZ newer and supporting things on the Intel side...
It looks to me like the Vishera with the 990FX chipset doesn't support some of the newer memory features/speeds that the Z77 chipset with say an i7-3770K does, but I'm looking forward to dropping in a new CPU when the last rev of AM3+ chips comes out, unlike what seems to be going on with Haswell, where I'd have to drop in a new mobo for a new cpu.
As a second-place option for mobo, I've also been looking at the ASUS Sabertooth 990FX R2.0 http://www.asus.com/Motherboards/SAB...specifications using the same chip. Would the recommendations for memory be the same for that one as the Extreme9? That one still lists as 32GB max, however.
And finally...does anyone know why memory prices slowly dipped down to a low point around Black Friday but are now almost double those prices? It wasn't just a "down for Christmas" thing; the graphs show them slowly all headed up. For instance: http://camelegg.com/product/N82E1682...utm_medium=www
